Posted by: | ![]() | EPHERE |
Data created: | 9 June 2015 |
+ Added: Installer support for 3dsmax Design version + Added: Per-strip hair distribution control for HairFromMeshStripsObject + Added: Per-strip hair volume diagram control for HairFromMeshStripsObject + Added: Multiple more curve controls can now be pannel with middle mouse button + Added: Thread pooling and better thread management to speed up all multi-threaded/parallel code + Added: If license was assigned to current computer it is now offered to be reinstalled via licensing dialog * Fixed: Major Edit Guides save/reload problem introduced in 4.0.1 * Fixed: Added the PhysX DLL's to the new installations for Max versions before 2013 * Fixed: Allow zero hair per strip for HairFromMeshStrips object * Fixed: Report error if load faild for HairFromMeshStrips object * Fixed: High CPU usage regression in HairFromMeshStrips object * Fixed: Correctly update hair if per-strip distribution method changed for HairFromMeshStrips object * Fixed: Clone correctly per-strip parameters for HairFromMeshStrips object * Fixed: Change correctly per-strip parameters for HairFromMeshStrips object on scenes merge/xref * Fixed: Edit Guide vertex data editing and scene reloading causes a crash Marsel Khadiyev (Software Developer, EPHERE Inc.) |
