Posted by: | ![]() | EPHERE |
Data created: | 22 August 2015 |
+ Added: Ox Guides from Shape can now be applied to NURBS curves + Added: Allow user to specify the maximum number of camera-facing hairs in viewport preview inside settings dialog + Added: An option in ground strands modifier to control which strand components are affected (position and rotation) + Added: "Hair from curves" groom + Added: Groom dialog now filters offered grooms based on the selected scene object type * Fixed: Crash with caching of hair from guides modifier used as guides for another hair from guides modifier * Fixed: Alembic exporter does not export animation for guides with ground strands modifier * Fixed: Installer doesn't install grooms into correct directory on some versions of 3dsmax * Fixed: Generate groom dialog has a useless "..." button. It now works. * Fixed: Icons in create groom dialog are not well aligned * Fixed: Impossible to specify licensing server IP other than default value (127.0.0.1) Marsel Khadiyev (Software Developer, EPHERE Inc.) |
