Posted by: | ![]() | EPHERE |
Data created: | 5 September 2015 |
+ Added: Option to export Alembic objects each to their own file + Added: "Generate Groom" button to the toolbar to allow creating new Ornatrix grooms from a selected object + Ground strands modifier's grounding performance improved (using a better geometric library and multi-threading) + All "Invert" map checkboxes are converted into better fitting image buttons + Toolbar images are updated * Fixed: Toolbar is not installed * Fixed: Alembic hair export hair width incorrect when loaded with V-Ray proxy object * Fixed: Errors when Ground Strands Modifier is applied to a mesh with degenerate triangles * Fixed: Crash when Ground Strands incoming guide count is increased * Fixed: Curve diagram in hair from strips, strands multiplier not redrawing when panned * Fixed: PropagationModifier diagrams do not render correctly * Groom dialog item names should use more friendly format * Fixed: Diagram modification undo is not work for Dynamic modifier Marsel Khadiyev (Software Developer, EPHERE Inc.) |
