cant be loaded. when starting up max2010 32bit. got an error message when loading the plugin.
failed to initialize. Error code 126 - The specified module could not be found.
with max2011 64bit all works well.
Mario Röske Technical Artist Piranha-Bytes
Seems like you could be possibly missing Autodesk.Max.dll in your Max root directory, or it can't find it for some reason. Please make sure that all files are installed properly as described here: http://ephere.com/autodesk/max/docs/1030.html
got it working. there was an update with .net 4.0 that i ididnt got. now its running with max2010 32bit as well.
