Posted by: | ![]() | Darholm |
Data created: | 18 September 2011 |
Hello, I'm trying the Spline Align tutorial and I have a problem with the windows form. When Max starts, it effectively loads the SplineAlign.dll because I see the form showing up, but it doesn't stay displayed on screen. It just pops and disappears. This is the code i'm using : SplineAlign.cs :
using System; SplineAlignDialog.cs :
using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using System.Text; using System.Windows.Forms; using Autodesk.Max;
namespace SplineAlign { public partial class SplineAlignDialog : Form { IGlobal global; public SplineAlignDialog(IGlobal global) { this.global = global; InitializeComponent(); }
private void SplineAlignDialog_Load(object sender, EventArgs e){}
private void button1_Click(object sender, EventArgs e) { MessageBox.Show("Hello World!"); } } }
Thanks for the help!
Darholm
14 July 2012
#3175 | |
try to create a userControl instead of a WinForm and call the *.dll using a dotnetControl in maxscript, something like this:
dotnet.loadAssembly @"C:\xxx\yourdll.dll" if classof yourRollout == RolloutClass then destroyDialog yourRollout rollout yourRollout "Title" width:Width height:Height ( dotnetControl nameControl "yournamespace.yourUserControl" pos:[0,0] width:Width height:Height ) createDialog yourRollout
where: yourRollout is the name of your maxscript Rollout nameControl: dotNetControl name yournamespace: namespace from your c# project yourUserControl: userControl name from your project Width: width of your userControl from c# project Height: height of your userControl from c# project
i hope it help you. Henriqu Melo. |
