Discuss Max.NET here !
Posted by:EPHERE
Data created:1 June 2009
Hi guys, Hope you are well and giving a try to Max.NET framework. I would be happy to discuss anything to do with this project with its users here. Don't be shy and let us know what you think! - Marsel P.S. I realize these forums are a bit primitive at the moment but we are working on them and they will get more interesting soon.
Hi EPHERE, I am Japanese. I am not good at English. Please teach me About the usage of MAXDOTNET. I try ... 1. Downloaded MaxDotNet103_June17_2009_3dsmax2010_win32.rar 2. Copyed Interfaces.dll, Interfaces.XML and MaxDotNet.dll to C:¥Program Files¥Autodesk¥3ds Max 2010¥ 3. Copyed MaxDotNetLoader.dlu to C:¥Program Files¥Autodesk¥3ds Max 2010¥Plugins and When I try to Launch 3ds Max 2010, the error occurs. ERROR System.IO.FileNotFoundException:0x80070002 System.Reflection.Assembly.nLoadFile(String path, Evidence evidence) System.Reflection.Assembly.LoadFile(String path) Autodesk.Max.Manager.LoadAssembly(String name) Autodesk.Max.Manager.LoadAssemblies() Autodesk.Max.Manager.Initialize() How should I do? Thanks.
Hi, Can you please list what is in your C:/Program Files/Autodesk/3ds Max 2010/plugins directory? It seems it is trying to load a managed assembly which is missing some .dll references. Thank you, Marsel
Hi, I list files in C:/Program Files/Autodesk/3ds Max 2010/plugins directory. --------- Folder Path : C:\Program Files\Autodesk\3ds Max 2010\plugins Total Size : 18,441 KByte [Plugins] EASYnatCore.dll EASYnatMax.dlo MaxDotNetLoader.dlu RPCShadows.dlo rpc.dlo rpcapi.dll rpccls.dll rpcfilterhost.dll rpcjpeg.dll rpcpopulate.dll vrayraw2010.bmi vrender2010.dlr [plugins\tentacles] [plugins\vrayplugins] [plugins\vrayplugins\DTE_Components]
Thank you, I will check this out. Meanwhile if this is causing too much problem I can send you an earlier version of Max.NET which shouldn't have this problem. Let me know. Marsel
Thank you! There is especially no probkem at present, and do not worry, please. I am expecting it of the Max.Net Project. I hope more programmers come to be able to develop 3ds Max plugin by using Max.NET. Sonata
Hi, When I tried to use Max.NET with 3ds MAX of a different version, The Error didn't occur. -->3ds MAX 2009 Sonata
Thank you Sonata Were you running 3dsmax 9 before that? There was a defect logged previously that seems very similar to this. Cheers, Marsel
Hi, It isn't possible to confirm the operation because I don't have 3ds Max9. Sorry. Sonata
