For 3dsmax versions 2012 SP2 and up (2013, 2014, 2015) you only need to distribute the assembly you compile (into /bin/assemblies/MyPlugin.dll). For prior versions of Max you will need to also install Max.NET found on our site. Yo do need to recompile your plugin for each Max version, however, you don't need to worry about 32 or 64 bit for older versions.
