Using external assemblies
Posted by:nikitamk
Data created:23 September 2009
Is it possible to use external assemblies in the managed plugin? I'm trying to use SharpSvn library from here - http://sharpsvn.open.collab.net/, and it gives me the following error:
"System.IO.FileLoadException: Could not load file or assembly 'SharpSvn, Version=1.6003.1304.38397, Culture=neutral, PublicKeyToken=d729672594885a28' or one of its dependencies. Invalid pointer (Exception from HRESULT: 0x80004003 (E_POINTER))
File name: 'SharpSvn, Version=1.6003.1304.38397, Culture=neutral, PublicKeyToken=d729672594885a28' ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at System.Object.GetType()
   at Autodesk.Max.Manager.AssemblyResolveEventHandler(Object sender, ResolveEventArgs args)
   at System.AppDomain.OnAssemblyResolveEvent(String assemblyFullName)
   at SvnMaxPlugin.SvnSaveActionItem.ExecuteAction()
   at Autodesk.Max.Wrappers.ManagedWrapperActionItem.ExecuteAction(ManagedWrapperActionItem* )"
Yes, I am doing it all the time (using external assemblies). Make sure you put all of the external assembliy dlls into 3dsmax root folder, and not the plugins folder so your layout should look something like:
3dsmax
   plugins
      my_plugin.dll
external_assembly1.dll
external_assembly2.dll
Hope this helps.
Marsel
