| Posted by: | MrSparkle | |
| Data created: | 10 May 2010 | |
Hi, is there a tutorial about how to add UI parameters to a geometry plugin? I tested the Plane geometry plugin example and tried to add some ParameterBlocks for the width and the length of the plane. The spinners are shown in the plugin's rollout but I couldn't manage to apply the chenged values to the plane's geometry. I guess the problem is to notify the plugin after the value has been changed in the UI, so the plugin can rebuild the geometry according to the parameters. Where can I find an example about the parameter block handling? Thank you, Christian | |
| 10 May 2010
#1929 | |
Hi Christian, I guess you already looked through the paramblock doc. The 'UpdateMesh' method should be called automatically when a parameter changes in the block. The only trick is to make sure you set the validity interval to current frame from what I remember. I will try to update the geometry plugin tutorial to include parameter blocks soon, or at least post a sample project for you to look at. Marsel Khadiyev (Software Developer, EPHERE Inc.) | |
| 18 May 2010
#1950 | |
Thank you, it works. I simply had to remove the line
from the BuildMesh-Method. Christian
