Hi! I wonder how I can create an object of the type ISplineShape. Seems like the corresponding method IGlobal.SplineShape.Create method is missing? Thanks, Christian |
| I tried: object result = global.CreateInstance(SClass_ID.Shape, global.SplineShapeClassID); ...but the result object is NULL. How come? |
| Hi Christian, Not sure at the moment (don't have access to the sources) but will check out why that constructor isn't exported once I do. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Hi Marsel, thanks you for having a look. I don't know if it could be helpful but the same happens when I use the class descriptor's Create method: object test = IGlobal.SplineShapeDescriptor.Create(loading); // Returns NULL Christian |
| The constructor wasn't exported because SplineShape derives from a whole bunch of classes privately, which usually gives link errors (while it doesn't in others) so the translator ommited it. I am working on this issue now, hopefully will be all resolved and dandy by 1.2.1 Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Ok, this is all sorted- fixed in 1.2.1 (next build) Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Wow, thank you! When is the next build online...? Christian |
| I'll try to get 1.2.1 out in next few days. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
