Mud explodes
Posted by:coilbook
Data created:6 February 2016
I attached the video
When mud wraps around the wheels it explodes in bursts.  I got 20 sub steps and 6 iterations Adhesion 0.8 Cohesion 0,2 Viscosity 0.05  Resolution is set to 50   Am i doing something wrong?
mud puddle is around 3 meters in diameter
Are there any best setting for mud that flies up and still gets stuck
Thank you
>Untitled.wmv (9248280 bytes),
And one more questions what should be bigger Sub-steps or iterations,  What is the best ratio?
What excatly means iterations?  it says number of solver iterations  but it is kind of confusing
Also if you look at the white truck frame and mud that is stuck, mud is not 100% stationary it is jittering. Not sure how  if once particles are stuck how to make them 100% stationary
Thank you!
The exploding from the video looks strange indeed. Do you think you can recreate the exploding problem in a smaller scene that we can debug?
Sub-steps are internal inside the physics solver, they are designed to prevent things like particles tunneling through collision geometry. Iterations are done outside of solver, they just break every frame into X number of sub-frames, these are done more for stability.
Yes I will send it shortly.  Do you have madcar 3 plugin by chance. That's what we are using to simulate a car. Then we add proxy cilinders for wheels and boxes for a car frame  and then we do simulation of mud
If you dont have madcar 3 I will try to just animate cylinders as wheels turning
Please try animating it. We try to avoid any 3rd party plugins in tests like these (removes complexity).
Hi Marsel Unfortunatly we have to use  madcar. But it is like animating mesh. Car dummy is animated and mesh is just linked to a moving dummy car.  So it is similar to dummy moving around with mesh attached to it. I attached couple of scenes
>mud+explosion+madcar+3ds+max+2014.max (11272192 bytes),
this one is without madcar and was just animated using keyframes but explosions still happen. Wheels get coasted with mud and for no reason mud just explodes.  This max file has a slight gap between wheel and actual surface (so there are particles between tire and surface) and it did improve a little     By the way do Dyn Friction, Stat Friction, drag, lift, damping apply to liquids? Not sure exactly which flex option are for liquids only. If not would be nice in the future to have little icons next to them like a drop of water, a piece of cloth so you know which flex settings are for cloth, for liquids etc.   But particles of dirt that are attached to truck still jitter a lot no matter what we did. Thank you
>crash+no+madcar.max (24506368 bytes),
Thank you for the scenes, we will investigate.
Changing substep count to 4 and iteration count to 3 fixes the problem.
The problem can be also fixed by setting maximum speed manually, check the Flex Settings helper for this. Value of 100 seems to be fine.
thank you! So more substeps does not mean better? I had around 60 substeps I guess it is overkill
Yes, not always. More substeps can make things too rigid which I guess can add to instability. Max. particle velocity is good for controlling stability, essentially you're creating a global speed limit.
Nice to know this.
Thank you!
