Hi, I have this cloth on an object and i wanna pull the cloth. How do i achieve that? I tried linking it to another object and it seems to stretch it or idk something weird. Im not sure about my cloth settings if are correct, i need work on this a bit more, but i want just a hint on how to do this. thanks |
| https://www.ephere.com/plugins/autodesk/max/lucid/docs/1/Simulating_Cloth.html#Fixing-cloth-vertices Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Thanks i saw most of the cloth tutorials. So whats the best solution for pulling a cloth? link it to another object? Can i link the vertices instead of the world position to another object somehow? thanks |
| Yes, have a look at Linked Xform modifier. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Idk what im doing wrong the vertices seem to not respond to my animated object but for many frames later. Maybe i should upload scene for u to take a look? thanks |
| Or actually what is a good range of sub steps or particle resolution for an accurate cloth simulation? I noticed btw that with the record button works much much more accurate. Is that normal? thanks |
| Generally the more substeps the better, some people do as many as 50. Not sure what could be wrong otherwise, perhaps have a look at the cloth sample scene and compare it to yours? Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Where can i get the sample scenes? thanks BTw it could be useful if u add some cloth presets so we dont have to dig up the friction and stuff. thanks |
| Have a look here: https://www.ephere.com/plugins/autodesk/max/lucid/docs/1/Sample_Scenes.html#Cloth-tearing Marsel Khadiyev (Software Developer, EPHERE Inc.) |
