Plush Toys Flying out help
Posted by:coilbook
Data created:4 April 2016
Hi Marsell
We are trying to make these two plush toys flying out in big numbers and land as plushes.
Could you help us to get started I attached the scene
Thank you
>plush+flying+out.max (2105344 bytes),
so i tried again using tutorial but when i hit simulate objects just lying up and never fall down like gravitiy does not work
I'll investigate this tomorrow, sorry for the delay. Just working on a fix with rigid bodies at the moment.
Please try in the latest nightly build (7200+), should be up in 20 minutes
thank you Marsel Night build did not work we are trying to get plushes flying out of the pipe and landing softly on the ground and mouncing too. We are doing test with cylinder and they are not even flying out but jsut appear arround the particle flow  I attached the file called TEST.max   Thanks
>test.max (319488 bytes),
here is one more scene called REVISED 2 sEems like it works a bit better now.  But we try to have more than one instanced object but PFlow does not lets us. is it possible to have more than one instanced object.  And looks like friction does not work at all and all objects just move on the surface
Thank you
>revised+2.max (2670592 bytes),
