Attach something to another end of the rope
Posted by:coilbook
Data created:10 August 2016
Hi we are simulating tow truck hook,  We were able to attach rope's top end to the tow truck arm but the bottom end must have a hook that moves around with the rope.  We cannot get it to work.  Can anyone help?
Thank you
>rope+test.max (376832 bytes),
Hi Marsel
we read your previous post but we just cannot make the hook travel with the rope.  Could you make a simple max sample?
This is wrecking ball effect we are trying to achive   https://youtu.be/68SlhHv5Q1E
Previous post "
Yes, you should be able to use curve physics. Just add a spline for the rope and throw Lucid Modifier on top. Select one of its end and use Linked Xform to make it being pulled by one object. Then use an attachment object to attach it to the second object.
I have fixed the scene:
1. Hook should be a rigid object
2. Lucid Attachment (New Object/Helpers/Lucid/Lucid Attachment) should be placed between the rope and the hook to attach particles
3. And I have increased number of iterations for more stiff rope simulation
The scene file
>rope_test.max (299008 bytes),
Thank you!
I did not even know lucid attachment exists
