Hi, I sometimes work in two separate locations. Is there an easy way to transfer the license between these two machines? They are not on the same network (I sometimes have to work from home). Thanks, |
| Hello, please use the "Reset License" link here and then reinstall on the other machine: ephere.com/plugins/autodesk/max/lucid/licensing.html Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Hi thanks for the quick reply. I can't see a link! Can I do this multiple times, as I switch between machines? |
| You can, though ideally it shouldn't be done too often. It is meant for the time when you are changing your hardware, for example. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Ok cheers. Still no link? |
| Hi Eddaly, This is the link: ephere.com/plugins/autodesk/max/lucid/licensing.html Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
