Help with animated model interaction with lucid
Posted by:amna100
Data created:15 April 2017
hello i have an animated model i have taken from mixamo.com and i'm having problems making it interact with lucid, for example i have included this animation i have https://gyazo.com/bfbc1b4131aae01f6c2cd402191e6eb6
once imported this fbx animtion into max and added the lucid modifier for convex
i have tried getting it to interact with soft bodies and liquids but it doesnt seem to be affecting them at all.
thanks
Hi Amna,
I don't have too much experience with Lucid yet, but I just tried what you descripbed and it seem to be working well. As you can see in the attached video I have three objects with the Lucid modifier, the Convex object is intereacting with the Fluid object.
>Untitled+Project.mp4 (17833807 bytes),
i see what you have done and this works for me aswell but the issue i describe is for animated models such as somebody walking and then exported to fbx and put into 3ds max
i included this image of the model i have https://gyazo.com/bfbc1b4131aae01f6c2cd402191e6eb6
The sphere interacting with the fluid was animation and then imported as FBX too. Let's wait for Marsel, he will be able to help you more than I. :)
i've included an example of the problem i am having. The plane is a collision, the box is a soft body and my animated model is a convex.
>test.mp4 (692324 bytes),
Hello, convex will not work on deforming/animated meshes. Please use SDF collision type instead.
thank you
Can i also ask about for example if i have a lucid modifier on liquid on my animated model how i could mantain the movement of the animation rather than when starting the liquid simulation it only keeps the transformation of the animation but not the movement of it
