i tried to make an realistic water fountain via PFlow + Lucid ... but i can't give good realistic results ... just fake fountain!! can someone helps? |
| any helps? i mean something like this
| Can you please explain what you mean by a "fake" fountain? Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| i mean the results are not as good as bifrost water preset for example , or realflow acts ... seems fake not realistic good :] |
| here is an quick test with 3dsmax fluid [milk preset] just by few clicks!! that now created.  how to do by lucid? |
| Did you see our tutorials on PFlow? https://www.youtube.com/watch?v=dEgh9RLVyCo&index=2&list=PLpRi3ovyFM-1wqPDHsbBDKbwY1pdKfOPL And other in this playlist. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| yes ... but the main problem is on meshing ... i mean bad mesh result ... does exists an good sample scene? |
| What is the problem with meshing? You can change granularity settings. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| well ... i tried to good setup of lucid fluid and display params inside PFLOW interface ... but seems that its useless plugin ... bad results on fluid simulation :\ sorry :[ |
