| Data created: | 24 March 2019 | |
New: Added Alembic export component options New: Added controls to randomize values in Change Width modifier New: Added Group Channel parameter to Frizz (to allow whole clump frizzing) New: Added Texture Mapping Method option to Propagator Fixed: Display exception with non-standard material and Optimized Mesh Fixed: Crash when opening some scenes with Push Away from Surface modifier Fixed: Channel list is not updated in Edit Guides Brush Options when adding or removing channels Fixed: DynamicsModifier PhysX 3 registration crashes in Max 2020 Fixed: Recording a Moov sim crashes Max when increasing 'SubstepCount' or 'CollisionTollerance' Fixed: Generate Guide Data modifier doesn't respect own or referenced node's changed pivots Fixed: Crash when Generate Guide Data modifier has 0 input strands and target data is texture coordinates Fixed: MoovPhysics crashes when simulating frame by frame Fixed: MoovPhysics inefficient multiple evaluation Marsel Khadiyev (Software Developer, EPHERE Inc.) |
