| Data created: | 7 August 2019 | |
New: V-Ray standalone procedural groom export including a new .vrscene exporter and V-Ray standalone plugin New: Option to load an Alembic file sequence in Strand Animation modifier using a pattern like "MyFile.###.abc" New: Texture map can be specified in Generate Guide Data modifier New: Adopt Shape option when planting roots Fixed: Grounding deforms guides shapes Fixed: Rotate operator does update viewport when using optimized mesh display Fixed: Clumper crashes after manually deleting/creating clumps and assigning external guides Fixed: Unable to comb hair generated with Hair from Mesh Strips Fixed: Crash when combing ungrounded Hair from Mesh Strips hair Fixed: Imported Alembic hair is not visible in the viewport when using optimized mesh Marsel Khadiyev (Software Developer, EPHERE Inc.) |
