| Data created: | 23 August 2019 | |
New: Animation Cache modifier loads Alembic sequence files on demand per frame (not whole sequence at once) New: Added options (export, time, etc.) dialog to .vrscene export New: Renamed Ox Strand Animation to Ox Animation Cache New: Added support for per-vertex strand rotations New: Added twist option to Strand Rotate modifier New: Added a Lengthener option to scale width values New: Added an option to set width by absolute strand length in Change Width modifier New: Grooms and curve presets saved in 3dsmax can now be used in Maya and C4D Fixed: Assertion/crash when serializing a stack with disabled/unsupported modifiers Fixed: Assertion when rendering with Corona Fixed: Mesh From Strands: ScatterMap doesn't work Fixed: Time offset in Animation Cache modifier doesn't do anything Fixed: Baked Hair object doesn't appear in viewports right away after being imported Fixed: Baked Hair Object grounding doesn't work properly with non-identity distribution mesh transforms Fixed: Edit Guides wrong scaling with multiple control points Fixed: Curl Operator: Slow performance when applied to propagated hairs Marsel Khadiyev (Software Developer, EPHERE Inc.) |
