| Data created: | 10 September 2019 | |
New: Add root-to-tip curve for Edit Guides control point influence New: Alembic export and Animation Cache modifier support ### in file names for exporting sequences New: Using per-primitive Alembic properties to store strand and vertex attributes Fixed: Scale Widths option crashes when input strands don't have width information Fixed: The distribution mesh is not animated in the Moov simulation. Fixed: Edit Guides control point rotation does not behave intuitively Fixed: Edit Guides: wrong local pivot with multiple control points Fixed: Roots are re-generated when the distribution mesh is deformed with Even and Random distributions Fixed: Crash when scrolling the animation bar with Moov on the modifier stack Fixed: Propagated strands can produce incorrect coordinates due to changing vertex space with invalid secondary transforms Fixed: Mesh from Strands Conform feature not working Fixed: Hair from Mesh Strips can freeze or crash with incorrect input meshes Marsel Khadiyev (Software Developer, EPHERE Inc.) |
