| Data created: | 6 December 2020 | |
New: Baking modifier works with strand point count changes New: Archived scenes include referenced Ox Alembic files Fixed: Surface Comb parameters not working Fixed: Strand stretching when combing multiplied hair with same roots Fixed: Merge: Unable to add strands Fixed: NormalizeStrands: Parameters do not work Fixed: Guide Clumping: The amount of clumps is not equal to the amount of guides Fixed: Import Spline places splines in wrong positions Fixed: Guide root positions don't update on animated mesh Fixed: Hair from Guides remembered roots not converted to poly on V6- scene open Fixed: Varying parameters don't respect UI range Fixed: Combing previously created guides with Create brush can modify existing input strands when Surface tracking is used Fixed: Elastic Rotate and Scale have very small strength in 3d mode Fixed: Create brush removes the newly created strands Fixed: Set texture coordinates doesn't work in ground strands Marsel Khadiyev (Software Developer, EPHERE Inc.) |
