| Data created: | 14 February 2024 | |
New: Converted Edit Guides UI to Qt New: Significant speed increase in Push Away from Surface operator New: Changing the groom directory in textbox updates the grooms list Fixed: Surface Comb: Unable to mirror sinks and some other issues Fixed: The selection brush stops working correctly if 'Affect Selected Only' is enabled Fixed: Crash with proxy meshes when input hair doesn't have a distribution mesh Fixed: [Edit Guides] Affect Selected Only doesn't work, when On. Fixed: [Edit Guides] Enabling Num.Control Points = 0 causes the program to crash. Fixed: [Rotate Strands] Realtime Update not working Fixed: MFS doesn't update when changing width of hair with proxy meshes Fixed: MFS: Cross section curve control not working Marsel Khadiyev (Software Developer, EPHERE Inc.) |
