| Data created: | 19 April 2024 | |
New: Circular brush mirroring performance is improved by ~90% (tested on 100K strands) New: FurBall groom has parameters New: Mesh From Strands: Added negative axis options to the 'Proxy Reference Up Axis' parameter. New: Option to set default strand channel values in Edit Guides New: Disabled all sticky parameters Fixed: Crash when importing some MetaHuman Alembic grooms Fixed: Guides close to UV edges will flicker on animation when texture islands are present Fixed: Crash trying to access dynamic parameter set descriptor owner Fixed: Incorrect direction used for MFS conform to surface option with proxy meshes. The results are also smoothed, like they are with flat/cylindrical hair. Fixed: Error/crash when loading Alembic files with unexpected property data types (e.g. when exported from Houdini) Fixed: Assertion/crash when Symmetry plane normal is not of unit length Fixed: 'Assert failed' error when baking the Propagation node Fixed: Edit Guides channel renaming is not saved with the scene Fixed: Edit Guides brush parameters are not shown when changing selected brush Fixed: Edit Guides - Comb, Local method doesn't work Fixed: Orientation issue with proxy meshes conform to surface option. Added smoothing. Fixed: Combing doesn't work in Edit Guides with YAML grooms Fixed: Strand Channels are not stored in the scene Fixed: Hair from Guides: 'Use Guide Proximity' checkbox does not work Fixed: Hair from Guides: Guide Area Calculation method does not have any effect Fixed: Root parameters in Edit Guides are not initialized in GUI Deprecated MassFX dynamics modifier Marsel Khadiyev (Software Developer, EPHERE Inc.) |
