| Data created: | 21 August 2024 | |
New: Allow applying Generate Strand Data values by strand groups (instead of individually per strand) Fixed: Edit Guides containing deletions and shape changes produce incorrect results on animated deforming meshes Fixed: Make sure propagated strands on a hair generated from a curve are correctly positioned on target mesh Fixed: Propagated strands should not be grounded Fixed: Incorrect twists and rotations when using multiple Rotate operators together Fixed: Conform to Surface uses incorrect "up" axis in Mesh from Strands Fixed: Cannot select groups with index larger than 31 with a pattern in Edit Guides Fixed: Update guide dependencies in Hair From Guides when input guides surface dependencies change Fixed: Rare exception when editing control points in EG containing strand deletions Fixed: Added the missing "Select by Group" checkbox Fixed: Proxy mesh button missing icon when in selected state Fixed: Missing parameters text when switching to EG Marsel Khadiyev (Software Developer, EPHERE Inc.) |
