| Data created: | 14 November 2013 | |
* Fixed: Mesh from strands modifier with proxy hair option is twisting the very last vertices in the wrong direction + Added: Distribution map for proxy objects in Ox Mesh From Strands * Fixed: A crash when adding a proxy mesh without texture coordinates to Ox Mesh From Strands modifier + Added: Mesh from strands modifier now inherits edited normals from incoming proxy meshes * Fixed: BakedGuides object's MaxScript .GetGuides() function now works * Transforms generated for each hair root are now aligned along the surface, regardless of whether polar interpolation is used * Generated hair is properly transformed into strand space instead of just being offset to origin * Fixed: Previous two fixes allow a fix for Ox Strand Curling modifier, which prevents flickering due to curl flipping around Y/twist coordinate * Fixed: A crash when only two guides are present and affine interpolation is used with 3 incoming guides * Updated documentation to reflect changes Marsel Khadiyev (Software Developer, EPHERE Inc.) |
