| Data created: | 6 March 2014 | |
* Fixed: Curve data is reset when object with Guides On Spline modifier is cloned + Added: S button (like in render settings modifier) allowing curve editor to pop up a separate window in Guides On Spline modifier * Fixed: Surface brush is now working + Added: A new "Smooth" brush which smoothes out affected guides + Added: A new "Revert" brush which reverts changes to the affected guides * Fixed: "Push Away" button now works properly * Fixed: Selecting some hairs using a brush then undoing the change restores an incorrect selection + Added: UV coordinates are exported into the Alembic file Marsel Khadiyev (Software Developer, EPHERE Inc.) |
