| Data created: | 7 April 2014 | |
+ Added: If there is a second per-root channel named "Groups" created in Edit Guides modifier its values will be used to assign propagation group values to the resulting guides. These can be used in Render Settings modifier to assign varying strand radius values for each group. * Fixed: Crash in UI when adding Strand Propagation modifier * Fixed: Adding Ox Dynamics modifier, then removing it and running MassFX simulation causes an error * Fixed: A sporadic crash due to the memory (de)allocation error in vertex normal computation algorithm * Fixed: Strange brushing behaviour with the comb brush * Fixed: Surface comb modifier's per-sink strength spinner now works * Many of the surface comb's sink-related methods are now accessible through MaxScript Marsel Khadiyev (Software Developer, EPHERE Inc.) |
