+ Implemented: Guides can now be moved along mesh surface in Edit Guides modifier root selection mode using standard Max transform tools
+ Implemented: Sink directions are now editable through "Sink Tips" sub-object mode in Surface Comb modifier using standard Max transform tools
+ Added: Add/DeleteSink FPInterface methods to Surface Comb modifier
+ Added: Surface comb sinks now have arrows displayed at tips
* Fixed: Brushes not affecting guides precisely in Edit Guides modifier when "Show Safe Frame" is on in viewports
* Fixed: Dynamics modifier simulation doesn't work if guides are exactly parallel to the ground
* Fixed: Dynamics modifier doesn't have to be selected in modifier stack to simulate properly
* Fixed: MassFX dynamics baking doesn't work
* Internal changes
