| Data created: | 10 May 2014 | |
* New: Nitrous viewport hair display (using mesh) with width and texture coordinate support (Max 2015 only)! Hairs under 10,000 vertices always face the view. * New: Mesh hair viewport display can be reverted back to previous polyline display through Listener->"OrnaAbout()" about/settings dialog. * New: Frizz modifier is now multithreaded * New: Maximum frizz amount increased to 12 * New: OXH hair export now exposed to MaxScript through "OxHairExport node filePath fromFrame toFrame stepFrame" function * Fixed: If a mesh without faces or vertices is passed into Guides From Surface modifier no guides are generated. This deals with Thinkbox XMesh blank mesh problem. * Fixed: Crash when using a distribution map in Guides from Surface modifier applied on top of Thinkbox XMesh * Fixed: Startup macrocripts installed into wrong directory causing Ornatrix menu entry not to be displayed * Fixed: Error and crash if using Hair Export modifier without a correct hair node selected * Fixed: When exporting animated hair to OXH file the vertex coordinates are not exported in object space causing imported animation to be incorrect Marsel Khadiyev (Software Developer, EPHERE Inc.) |
