| Data created: | 23 May 2014 | |
+ New: Added UI curve control for Strand Frizz Modifier frizz amount * Fixed: Hair not sticking to distribution mesh during render when it is generated on top of Ox Guides From Guide Mesh modifier * Fixed: Changing selection of underlying mesh updates guides from mesh modifier's output when using sub-selection option even if it isn't the current modifier in the stack * Fixed: Hair from guides modifier not updating when distribution map is changed and the modifier is not selected in modify panel * Ornatrix brushes assign weights to strands based on the relative size of each segment to brush size instead of distance to center of the brush. This prevents small brushes from being ineffective. * Brush strength can be increased to 10 through GUI (was maximum 1 before) * Fixed: Defect 2266, ground strands modifier only offsetting hair without rotating it + Added: Ground strands modifier "Ground" method exposed to MaxScript Marsel Khadiyev (Software Developer, EPHERE Inc.) |
