| Data created: | 8 August 2014 | |
+ New: Symmetry Modifier - Added an option to not mirror strands which are closer to the mirror plane than a certain value + New: Hair from mesh strip support for meshes with multiple elements + New: Hair from mesh strips can now inherit mesh strip UV coordinates * Fixed: Strands are rotating during mesh deformation when ground strands modifier is used * Fixed: Guide generated at origin when "topology orientation" option is off * Fixed: Crash when using guide mesh export with hair from strips object * Fixed: Curling modifier jittering * Fixed: Strips mesh jumps when OX Render Settings is above it * Fixed: Alignment with strips that have modifiers and/or pivot changes * Fixed: Mesh strip direction arrows and stems were not displayed correctly * Fixed: Dissapearing hair when selecting one of the mesh strips in sub-object mode * Fixed: Crumpled hair with Turbosmooth removed from a mesh in Hair from Mesh Strips object * Fixed: Crash when undoing turbosmooth deletion in Hair from Mesh Strips object Marsel Khadiyev (Software Developer, EPHERE Inc.) |
