| Data created: | 15 November 2015 | |
New: Ability to pan/zoom in a graph/curve editors New: All graph/curve editors now support undo/redo New: Mesh from strand billboard UVs now respects strand thickness New: Rotation attribute data for hair New: New Grooms feature (XML format for defining hair presets) New: Added support for NURBS curves to Ox Guides from Shape modifier New: Added option to ground strands modifier to control which strand components are affected New: Deforming collision meshes are now supported in PhysX dynamics New: Nearly all maps used in Ornatrix now have an invert option New: Switched to new MSI based installers for easier distribution and deployment of Ornatrix New: SDK and Maxscript access to Ornatrix version information New: Multiple hairs per follicle using new Strand Multiplier modifier New: Hair from Mesh Strips now allows "fanning" hairs perpendicular to strip surface New: Show named selection sets for sub-object in Edit Guides New: Installer now offers options to install for 3dsmax Design New: Add support for varying hair strip parameters New: All points in curve editors can be moved and deleted New: Ability to specify install locations for specific components using new installer New: Z-up, Y-up, or X-up orientation export for Alembic New: Added an option for Alembic exporter to export render version of hairs New: Added an option to export Alembic objects each to their own file New: Allow user to specify the maximum number of hairs in viewport preview which face cameras New: Converted all "Invert" map checkboxes into image buttons New: Surface brushing performance and functionality is improved New: GUI improvements with real-time feedback of brush strength and size in modify panel New: Pull brush for straightening out hairs New: Ability to lock surface brush through modify panel, without having to press Ctrl key New: Added a label in EditGuidesModifier to show current guide selection New: Improved performance of GroundStrandsModifier grounding New: Icons for multiple Ornatrix operators New: 3dsmax 2016 support New: Quick hair button now adds VRayOrnatrixMod if renderer is V-Ray RT New: Add ability for .oxgroom files to store and display a thumbnail Fix: Flickering in root moving and grooming and bad root interpolation Fix: Edit Spline not working with Adopt from Stack Fix: Frizz not working as expected Fix: Crash when creating then deleting Edit Guides root data Fix: Proxy meshes are being deformed incorrectly Fix: Frizz modifier amount map is not working as expected Fix: Issues with gravity modifier. Lost curve after saving and loading scene Fix: Index out of range after changing root count and using Edit Guides modifier Fix: HairFromMeshStripsObject is not updated in the scene view with animated parameters Fix: Strand propogation modifier freeze Fix: Guides on spline crash Fix: Edit gudies crash Fix: Strip selection in Hair from mesh strips object is not updated correctly in Wireframe scene view Fix: Symmetry modifier plane vector is not draw correctly in some positions Fix: Length modifier randomize seed is not working Fix: Failed asserting at Matrix::LookAt Fix: Edit Guides loading error (binary I/O) and crash Fix: Customer-reported issue with the new Strand Multiplier modifier Fix: Hair clustering modifier produces different clusters in viewport on each run Fix: Frizz diagram crash Fix: "Hair from mesh strips" and "strand multiplier" GUI is gone Fix: Edit Guides plant root crash reported by customer Fix: Ornatrix Script Error on CAT bones Fix: Crash rendering Mesh from Strands with V-Ray without UV coordinates Fix: Ornatrix toolbar doesn't get installed Fix: Alembic export crashes when trying to export multiple objects Fix: Ornatrix HairLength map modifier broken Fix: Error in GuideDelta when deleting roots in user-provided scene Fix: Last point of hair clustering diagram is not editable Fix: Issues with Edit Guides corruption on scene save Fix: After recent merge Hair from Mesh Strips diagram broken again Fix: VRay distance texture does not work with distribution maps Fix: Detail modifier not smoothing interpolated strands Fix: Dynamics diagram editor works very unreliable Fix: Toolbar is not installed for non-English versions of Max Fix: Crash when changing strand point count before ground strands modifier Fix: Crash when ground strands distribution object is deleted and scene reloaded Fix: Saving and re-loading Wikihuman "digital Emily" model does not preserve guides shape Fix: Hair clustering modifier is not applied when rendering Fix: If scene has two objects with same name Alembic export crashes Fix: Install (copy) groom templates into /plugcfg/Ornatrix/Grooms Fix: Ornatrix dynamics exception and inability to simulate Fix: Crash with caching of hair from guides modifier used as guides for another hair from guides modifier Fix: Installer doesn't install grooms into correct directory on some versions of 3dsmax Fix: Alembic exporter does not export animation for guides with ground strands modifier Fix: Icons in create groom dialog are not well aligned Fix: Generate groom dialog GUI cleanup Fix: Generate groom dialog switch to Qt Fix: Implement groom dialog filters Fix: Crash when undo after editing frizz diagram Fix: Diagram modification undo is not work for Dynamic modifier Fix: PropagationModifier diagrams do not render correctly Fix: Curve diagram in hair from strips, strands multiplier not redrawing when panned Fix: Installer throws an exception when trying to execute the AddToolbar action Fix: Failed assert/crash probably from GroundStrandsModifier Fix: Assertion failed if GroundStrandsModifier applied for mesh with degenerate triangle Fix: Calling Logger::Instance.Log from different threads causes deadlock in Ornatrix for Max Fix: Alembic hair export hair width incorrect when loaded with V-Ray proxy object Fix: Groom dialog item names should use more friendly format Fix: Generate toolbar icons from SVG files Fix: Guide clustering modifier maps don't work Fix: Replace ANN library with a more modern alternative Fix: Installer only installs toolbar for first version it encounters Fix: Mesh from strands produces noisy tips for flat proxy meshes Fix: Add hair menu option in non-QT Max (2013 and below) does nothing Fix: Installer problem when batch installing on network drives Fix: Unwanted guides/hairs get planted when sub-selection option is on Fix: Comb brush works incorrectly in orthographic views Fix: Crash when opening our bat sample scene Fix: Hair is always displayed black in Nitrous viewport Fix: "View polygon hair" global setting does not survive 3dsmax restart Fix: "Remember" button in Guides from Mesh Object does nothing Fix: Rotate strands modifier doesn't use map and channel multipliers if orient based on strand is on Fix: Rotate strands map doesn't produce real-time feedback when using color picker in medit Fix: Push away from surface option in edit guides produces incorrect results Fix: Viewport and render normals are facing the wrong way Fix: Adding surface comb sink to a face and reducing mesh face count causes a crash Fix: Crash adding Detail modifier on top of HairFromMeshStrips object Fix: Crash when changing strand clustering twist value to a small value Fix: Default feathers groom is not working Fix: About box should indicate demonstration version somewhere Marsel Khadiyev (Software Developer, EPHERE Inc.) |
