| Data created: | 21 January 2016 | |
+ New: Ability to select target 3dsmax versions in MSI silent install mode (see docs for description) * Fixed: Frizz modifier stops working after 90,000 hairs or so * Fixed: Frizz modifier applied to hair from hair strips changes as strip mesh is rotated * Fixed: Crash when applying texture map to render settings thickness * Fixed: Crash using VRay hair primitive * Fixed: Sending 0 strands into hair clusterer crashes Max * Fixed: Internal errors when applying detail modifier * Fixed: Crash when brushing guides with a 3dconnexion mouse used * Fixed: Ornatrix crashes when using guide clusterer with a vertex color distribution Marsel Khadiyev (Software Developer, EPHERE Inc.) |
