| Data created: | 8 February 2016 | |
+ New: Grooms can now be scaled before creation to increase or decrease the resulting real-world size + New: Groom detail can now be changed before creation to make them more or less detailed * Fixed: Dynamics starting segment map doesn't disable the last segment for black values * Fixed: Crash in scenes with iterative hair from mesh strips usage * Fixed: Frizzer flips results around if they are bent beyond 90 degrees * Fixed: Hair from mesh strips sub-object display is off or not visible * Fixed: Brush direction is reversed at some angles of the viewport * Reorganized layout of Hair From Guides modifier to make viewport and render count controls more visible * Fixed: Alembic export doesn't export width for hair from mesh strips objects * Fixed: Setting number of material ids in mesh from strands produces one mat. id. less than value set * Fixed: Hair from mesh strips not present in renders when it is selected * Fixed: Crash when repeatedly connecting to license server over IP on a slow network * Fixed: Created grooms do not assign default values to sticky 3dsmax parameters Marsel Khadiyev (Software Developer, EPHERE Inc.) |
