4.2.7.7127
Posted by:EPHERE
Data created:28 March 2016
+ New: Made Gravity modifier part of hair grooms
+ New: Made distances in grooms always be in centimeters
* Fixed: Base channel parameter not used when inheriting proxy mesh UV coordinates
* Fixed: Guides snap back to original shape if animated and combed at non-0 frame
* Made "Base object is optional" true by default in grooms generator
* Fixed: In some cases hair shape is not updated during rendering
* Fixed: Cluster modifier diagram reset after cloning
* Fixed: Gravity Gizmo is not rotating in the right direction according to the gizmo
* Documentation update
We're running on max 2016, and this build seems to have vertex colour map problems. I had a crash on load which I believe was also down to vertex colour map being used on a modifier. Basically, I can't get any vertex or mapping channel assignments to work as they should. This has broken since v4.2.5 (I've just swapped out and it works ok in older version)
Cheers,
Tom (Realtime UK)
Hi Tom,
There have been fixes for this since the last build. Have you tried installing the nightly builds?
Thanks marcel,
I've just been trying 4.2.7.7215 (on two different max installs as we were getting slightly different results on different PCs with v4.2.7.7127). The nightly build works better but is still not quite right I'm afraid.
My test scene consists of:-
build a sphere, apply vertex paint with say a white strip on black. Now add guides from surface and use vertex paint for distribution. On previous version this worked on one PC but not on another, but with nightly now it seems to only work if you select map channel 1 instead of vertex colour.
Now I go back down stack and add another vertex paint to say mapping channel 10, and up to top to use this on strand length modifier.
with latest nightly (7215) this works, but on 7127 it would crash.
My second test is a more complex full head groom built with an older version. This crashes on load on both the latest 4.2.7 versions (stable and nightly) and I'm fairly sure the crash is down to a length mod that uses vertex colour. It opens okay on v4.2.5 though.
Anyway, I hope this helps getting to the bottom of it,
Cheers,
Tom
Hi Tom,
I am about to get a new version out. Would it be possible to send me the scene which crashes to my email (marsel.khadiyev (at) ephere.com)? I can then investigate the crash.
