| Data created: | 14 June 2016 | |
+ New: Added strand group index parameter to length modifier * Fixed: Base mesh not added to generated grooms when source hair is on a referenced object * Fixed: Failed assertion and a crash in Hair from Guides when changing some export data options * Fixed: Create hair on an object with moved pivot created hair in wrong place * Fixed: Crash when changing the guide count when ground strands and surface comb are on top * Fixed: Max crashes when hair is assigned a mesh channel from a texture map channel which does not exist on the mesh * Fixed: Setting vertex color as a map source doesn't work * Fixed: After closing groom select dialog in Max 2017 user can no longer use the create/modify panel * Fixed: Modify panel toolbar images do not show up in 3dsmax 2017 * Fixed: Assigning per-vertex color channels to parameters does not display and set the correct channel index * Documentation updates Marsel Khadiyev (Software Developer, EPHERE Inc.) |
