| Data created: | 6 September 2016 | |
+ New: Guides from Shape Object which allows multiple animated shapes to be used as guides + New: Push Away from Surface modifier + New: Added pen pressure multiplier to brushes + New: Ability to toggle shape and directional changes by Surface Comb Modifier + New: Sinks detaching/reattaching in SurfaceCombModifier to allow changing surface topology + New: Added "viewport preview only" option to hair clustering modifier + New: Option to detach roots in Guides from Mesh modifier to allow changing surface topology + New: Added tooltips to all hair clustering modifier parameters to clarify their function * Fixed: Clustering followed by strand frizz on a deforming mesh causes popping * Fixed: Length modifier applies to strands with group 0 in all cases * Fixed: Cloning object with SurfaceCombModifier does not preserve sinks * Fixed: Texture coordinates not passed to V-Ray when using Hair from Mesh Strips * Fixed: Clustering takes too much time for many strands due to Max array storage * Fixed: Use guide distance and guide distance options in HFG don't do anything * Fixed: Collapse All for a large hair stack sometimes crashes Max * Fixed: SDK zip file is missing required headers - Removed: Unused sub-object levels in hair clustering modifier Marsel Khadiyev (Software Developer, EPHERE Inc.) |
