| Data created: | 12 August 2018 | |
New: Capture and resetting of initial Moov simulation state New: Simulation of Moov simulation rest state New: Alembic Importer New: Added browse button for Moov simulation scripts New: Loaded file information to Strand Animation modifier New: Added undo/redo support for strand grounding New: Added option to mirror Edit Guides brushes in world space, by default it mirrors in object space Fixed: Added Moov Python scripts to deployed 7z archive Fixed: Alembic Baked Hair objects disappear when reloading the scene Fixed: Moov simulation stops working after selecting the Moov modifier in the modifier stack Fixed: Target object button is disabled in Generate Strand Data modifier when Is Inside Object method is used Fixed: Disable external clumps and count options when changing clump generation method Fixed: External Strands generation method doesn't work in Clump modifier Fixed: Planting multiple guides in the same spot prevents edits to those guides Marsel Khadiyev (Software Developer, EPHERE Inc.) |
