| Data created: | 27 August 2018 | |
New: Added Optimize Strands and Resample Strands options to Edit Guides New: Hair preview in viewport is up to 3x faster New: Much improved hair interpolation (WIP) Fixed: Moov simulation stops working after selecting the Moov modifier in the modifier stack Fixed: Moov simulation behaves differently when dragging time or using real-time playback Fixed: Modifying Resolve Collision parameters doesn't update the modifier's effect immediately Fixed: Incorrect GUI name for Push Away from Surface modifier curve Fixed: Memory consumption grows when dragging change width value (memory leak) Fixed: Importing Alembic file with multiple animated strand object can produce incorrect results Fixed: Strand Animation modifier is evaluated at every frame, regardless of whether there is animation or not Fixed: Alembic archives with multiple objects cannot be used to load hair animation Fixed: Assertion Error when opening scenes made in previous builds of V6 Fixed: Curve editor diagram existing values can be mutated by dragging other values Fixed: Detail modifier smoothing does not work in some cases Fixed: Delete Clump(s) button in Clump node deletes all clumps regardless of the selection Fixed: Symmetry operator doesn't copy strand groups Fixed: Baked guides don't save strand groups Fixed: Mirror brush doesn't affect all brushed strands equally Fixed: Planted guides don't inherit the strand group of the selected guide Marsel Khadiyev (Software Developer, EPHERE Inc.) |
