| Data created: | 29 October 2018 | |
New: Generate Guide Data has Target Data parameter allowing to alter various parts of hair data including texture coordinates New: Implemented Generate Guide Data Is Inside Object option New: Gravity operator is multi-threaded New: Symmetry operator copies texture channels Fixed: Detail modifier doesn't set the resulting hair texture coordinates Fixed: Curling modifier texture coordinates don't work with maps Fixed: Some unit tests fail on hi DPI monitors Fixed: Max asserts when baking hair with Push Away from Surface modifier in the stack Fixed: Mirrored sinks change on deforming mesh after a scene reload Fixed: Hair roots shouldn't change on a deforming mesh during single frame render if 100% of hairs are previewed Fixed: Changed Oscillator force multiplier to closer match Max forces behavior Fixed: Wrong Hair UVs coordinates when using the "Use Guide Proximity" option Fixed: Assertion when inserting a knot into an empty ramp diagram Marsel Khadiyev (Software Developer, EPHERE Inc.) |
