| Posted by: | somayrah | |
| Data created: | 20 June 2019 | |
Hello, I have a problem when I use interactive corona renderer or GPU on vray next also. 1- when I used interactive corona renderer the hair count at the view port changed to be full count with 600K. this problem make the view port browsing so hard and computer very slow. 2- on Very next GPU also same if I use GPU rt I can not use the view render hair count it just read the viwe port hair count and in this case I should use full hair count and in this case I got the same problem for making the 3ds max very slow and heavy becuse of the harge number of view port count. Do you have any idea or solution please ? Thanks. Saad |
