Different materials
Posted by:mediaramas
Data created:31 July 2019
Hello, I have created two OX sets of hairs created with "guides from surface", I want to apply different materials to each set but it seems that both hairs grab the material from the base object, is there any way to achieve that?
Thanks in advance!
It works fine here. Be sure you are applying the hair to the hair objects and not the distribution mesh, see the image below. I also attached a scene so you can test.
