Is there anyway to create Ornatrix between 2 spline without any scalp object ?
Posted by:agphd
Data created:9 September 2019
Dear Ornatrix,
You know, it is possible to create 'Hair and Fur' between two spline without any scalp object in 3ds Max.
If I'm missing something, please let me know.
Thank you.
I think the 'Ox Hair from Mesh Strips' might be the answer what I was looking for. However, I wanted to use 'Custom user Proxy-Mesh' on this function.
I noticed if I use 'Cusome user Proxy-Mesh' on the Mesh Strips, and bend the strip, the Custom user Proxy-Mesh is going to be thinner or flipped  on certain angle.
Is there anyway to use 'Custom user Proxy-Mesh' follwing the normal direction of a face or direction of spine?
By create hair between two splines do you mean hair interpolation? If so, that's not possible. The interpolation algorithms need a distribution mesh to work.
About your problem with proxy meshes, try rotating the proxy mesh in object space on a single axis at a time until you find the correct orientation.
Thank you for your kind quick answer. I really appreciate it,sir.
