Alembic Export through Maxscript
Posted by:nweeden
Data created:20 September 2020
Hi,  I was looking at your documentation for exporting alembic through Maxscript.  The page seems to be out of date, there are many more options on the export dialog for 6.3.  Are there more up to date instructions so I can get full access to all the options for exporting?
https://ephere.com/plugins/autodesk/max/ornatrix/docs/4/Alembic_Export.html
Nick
No updates on this?  I'm just trying to work out how I can consistently export from Max using Maxscript but I don't have any access to the new options on the export GUI, the command from the documentation doesn't include any information for example on the different "Export Components" or the "Unreal Engine 4 Export".  Any ideas if these are even controllable or how they are accessed?
<code class="sql syntaxhl">OxAlembicExport [string filePath] [bool exportSelectedHairs] [int startFrame] [int endFrame] [bool exportRenderVersion] [int upDirection] [int format]</code>
Currently this is not possible with the current version. Only some of the export options can be accessed using MaxScript, which can be found here: https://ephere.com/plugins/autodesk/max/ornatrix/docs/6/Alembic_Export.html
We are looking into adding this feature for the next major version.
Hi Jeordanis,
I thought that might be the case.  Is there a timeline on when this may be available?  And how the new setup will work?  We use Ornatrix a lot and it would be very useful to be able to control how we output Alembics with more control.
Nick
Hi Nick,
I don't have an ETA for this feature, but you can keep an eye on V7 beta releases to be up to date. Meanwhile you can access those options through the UI.
This is implemented on Ornatrix V8 beta for Max.
