- In "Import Spline" of Edit Guides, no strand is generated at the point where the mouse is clicked. Generated in unpredictable locations.Screen capturehttps://drive.google.com/file/d/1URulFWKGICoo7iHD8IFdBeaRwUgugtkM/- The Ox Normalize Strands modifier doesn't work at all.
Best wishes,-------Yuji YamauchiOakCorp Support
I can see that there is a problem with the Import Spline tool. For now you can use Import Multiple, which works fine from my tests.
I tested Normalize Stands, it works fine here. Can you show me the issue in a video?
Thank you.
"Import Multiple "works, but Please fix "Import Spline". Parameters do not work for Normalize Stands. This is a video.https://drive.google.com/file/d/1k_8qsh4QdTepN8UspPm9JQsHC8skTx01/
Parameters in Normalize Strands fixed.
Import Spline command fixed.
Thank you for the fix.
The fix made it better, but it still has the following bugs:Import Spline - The Distance Thresh parameter is not working. - The Custom Point Count operates in the ON state even if it is unchecked.Import Multiple - Custom Point Count operates in the OFF state even if it is checked.
Confirmed with Ornatrix 7_7.1.2.26290 [Nightlies]
