Hair from Base mesh??
Posted by:davoodkharmanzar
Data created:4 January 2022
hi ...
what is the easiest way to create hair from Base mesh?
does exists any scripts or modifier for that?
It depends on how this base mesh was constructed.
If those are open tubes without triangles, you can use Hairs from Mesh Strips to convert them to hair.
If the base mesh is not appropiate to use with Hairs from Mesh Strips, maybe you can extract curves manually from the base mesh and use them to generate hairs with the Guides from Shape modifier.
