3dsMax 2021, Arnold Renderer, Ornatrix Demo - not rendering
Posted by:jbillet
Data created:10 February 2023
I am using the Demo version of Ornatrix to test out with 3dsMax and it works fine with the scanline renderer, but not with Arnold. When I render Ornatrix with Arnold, hair does not render.
I've added the Ox Arnold modifier and applied Arnold Standard Hair material to hair object.
Is this a known issue? Is it a limitation of the demo version? Am I doing somthing wrong?
Thanks for any tips!
J
Any thoughts on this? Still struggling to get up and running. I've tried bot hthe 'Ox Hair Raytrace Fast' and 'Ox Hair Raytrace Accurate' in the Atmosphere>Effects panel. The only success I've had is using the 'Ox Mesh From Strands' modifier which doesn't seem like it should be necessary.
Looking back I'm not sure that I was ever able to render even using scanline unless I added the 'Ox Mesh From Strands' modifier.
Sorry for the delay. Are you on the latest version of Arnold? Otherwise you may need to update it to get it working properly with Ornatrix. Arnold is fully supported even in the demo.
Jeordanis,
Success! That was the issue. I've updated Arnold to 5.5.2.9 for 3dsMax 2021 and Ornatrix is now working. Thanks for catching this.
J
