Unable to export animation for hair generated from mesh strips
Posted by:kuvaja
Data created:16 November 2023
Hi
I'm trying to export an ornatrix alembic file with animation, but I only get one frame saved. Hair is generated from mesh strips. Any ideas why this happens?
screenshot
Kind regards
Siim
Ornatrix hair animation needs to be loaded using the Animation Cache modifier:
  1. Export the hair as Ornatrix Alembic, make sure to specify the range of animated frames,
  2. Import the hair back as Ornatrix Alembic. It will create a new BakedHair object,
  3. Add Animation Cache modifier to the hair object just created and load the same file in it again.
