V8 missing feature from v7
Posted by:koko93s
Data created:14 April 2025
Hello!
I'm currently testing v8 after having used v7 for years.  In v7, in the Hair From Guides modifier had a section under Dense Hair Settings called Export Object Type and you could select Hair or Guides.  I cannot find anything similar in v8, so everything I export to Unreal is guides only.  Is there a similar setting/function somewhere else in Ornatrix V8?
Thanks!
Do you mean that you export hair only (since that's what Hair from Guides generates)? If you want to export guides instead of hair you can add a Guides from Hair modifier on top.
I was looking to export the abc as hair not guides.  As I said, V7 has that set of buttons you could choose what gets exported, hair or guides.
In Unreal if you import the abc from V7 and had selected hair, you would get hair, otherwise you would get guides.
In V8 there is no setting I can find and even with Hair from Guides on the stack I get guides only, not hair, as evidence by the strand count in Unreal which matches the amount of guides I have, not the amount of hairs.
